earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
I went with the Kimpex connect system with the 2 gal rotopax and Kimpex bag....I'm still waiting on the b/o tank holder. I also installed bop rear tunnel supports just in case. Pics once it's all on.
Mounting the kimpex connect rail this weekend. The rails will act like a stiffener and hopefully, allow me to connect linq brackets/mounts as well. This will give us a lot of flexibility in who is carrying what on the sleds. The rails also allow you to easily slide the connect mounts (or linq mount) forward and backward. This provides further flexibility as I can run just the mid size tunnel bag most days, and then switch between connect bag, fuel can, linq accessories, or whatever. I prefer the connect for its ability to stack more sensibly and the various accessories are way cheaper than the linq accessories.
MyOutdoors
- May 4, 2003
- Lempster, NH
- 2020 Sidewinder Ltx Se
I figured the Xtra support couldn't hurt. I do alot of solo rides from my backyard and go anywhere from 100-200 miles. I like to carry alot...just in case! The rails definitely give alot of options. not many people seem to run this systemMounting the kimpex connect rail this weekend. The rails will act like a stiffener and hopefully, allow me to connect linq brackets/mounts as well. This will give us a lot of flexibility in who is carrying what on the sleds. The rails also allow you to easily slide the connect mounts (or linq mount) forward and backward. This provides further flexibility as I can run just the mid size tunnel bag most days, and then switch between connect bag, fuel can, linq accessories, or whatever. I prefer the linq for its ability to stack more sensibly and the various accessories are way cheaper than the linq accessories.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Trail tank update.
I finally got to go out for some trail miles today and filled my sled for the first time.
Issue 1. I put the fuel level sender in wrong. The float would not go all the way to the top. I need to turn the unit 90 degrees to fix the problem.
Issue 2. While fixing my mistake on the sending unit, I saw a small amount of fuel on top of the pump sending unit. I looked closer and could see fuel coming up through the screws that hold the sending unit in. With the trail tank, the screws go all the way through the tank shell and into the tank. I removed all the screws and sealed them with some fuel resistant sealer. I then jacked the front of the sled up for a bit to see if the fuel would come out. So far so good.
Just beware, when installing the tank sending unit, seal the screws holding it on.
Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '21 SRX, '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F,
I just purchased a 2021 SRX that has the 12 gallon tank and the stock tunnel bag will not fit with the added capacity tank. Does anybody know of a tunnel bag that will fit with the bigger tank?
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I installed this. You need the base kit also. Much nicer than the stock bag, easy to remove.
Mills
- Dec 4, 2007
Looks a bit bulky but if that is all that is available, I might have to try it. Is this the Cat Attaché bag and mounting system?
Mills
- Dec 4, 2007
Do you have any pictures of this on your seld? this is a marketing picture that I find anytime I look for Atach saddle bags.I installed this. You need the base kit also. Much nicer than the stock bag, easy to remove.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
check earlier posts in this thread....
Mills
- Dec 4, 2007
Thanks for the pic. How well has the 12 gal. tank worked for you? I bought my sled with it already installed so I don't know much about them. Did you reuse the fuel pump/sending unit from the stock tank? Also, I read that the bolts holding the pump/sending unit in the larger tank have to be sealed so gas does not migrate out through the threads. Is this something you have done as well? Any other things I should know about this tank? Any info you can pass along would be very much appreciated. Thankscheck earlier posts in this thread....
Mills
- Dec 4, 2007
STAIN, I bought a '22 SRX with the same tank and it is leaking like crazy through the screws that secure the pump/sending unit. What did you use for a sealant? Is there any sort of recall on this from Trail Tank or a possible fix/solution they suggest?Trail tank update.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Put some of this stuff on the threads of the screws. Worked well for me.
Mills
- Dec 4, 2007
I called the number listed on the site for Trail Tanks and they answered right away. They know about the problem and are sending a free kit out to fix the issue. Includes two o-rings as well as new screws and sealant.
