srx700lt
- Mar 29, 2006
- Sweden
- Sweden
- SW XTX-146 SE
I have a Sidewinder XTX 146 SE - 20, and now I'm thinking of swapping the track to a one with larger lugs. Anyone done that and has any advice?
I was planning on getting a 2 1/4 (57mm) but it appears that is not available so the next is 2 1/2 (64mm). Does that work with 8 tooth drive or do I need to go to 7 tooth?
Ylisijo
- Apr 3, 2022
- Suomi
- Other
- Yamaha sidewinder x-xt se 146
Challenger extreme 64 and original 9t 2,86 drivers it just have enough room to rotate freely
srx700lt
- Mar 29, 2006
- Sweden
- Sweden
- SW XTX-146 SE
That is exactly what I am planning on doing. But it must be extremely close to the cooling lines in the tunnel?
And the rear bumper, is it from a 141"?
Ylisijo
- Apr 3, 2022
- Suomi
- Other
Clearance to hoses in front is 1,5cm. Rear tunnel, cooler hoses and bumper is cut 15cm shorter.
- Feb 13, 2017
- Amston,CT
- Renegade 900 ACE,XF 9000 Crosstour,2024 Skidoo Renegade XRS 900R
FWIW I run the Camso Hurricane 175 2 ply with #270 SS28R iGRIP racing studs.on my 2018 xf9000 146”Crosstour.over 3k currently on trac.no issues.
Mason Sorensen
- Nov 8, 2017
- Iowa
- 2016 Yamaha Viper MTX 162”
MPI Turbo
Dyno Jet Power Commander Ulmer
Black Diamond Pro-shift weights
Black diamond Helix
Tether kit
Grimm Speed Boost controller
SLP Mohawk SKIS
Sidewinder heated ROV
Custom built stainless exhaust
17.5 limiter straps
Stingray Spring
I’m working with the same sled a 24 xtx 146 so a 2.5 does fit in there with stock drivers? Or what did u have to do to make it fitChallenger extreme 64 and original 9t 2,86 drivers it just have enough room to rotate freely
Mason Sorensen
- Nov 8, 2017
- Iowa
MPI Turbo
Black diamond Helix
Tether kit
SLP Mohawk SKIS
17.5 limiter straps
Stingray Spring
Did it fit and work? Or what parts were neededChallenger extreme 64 and original 9t 2,86 drivers it just have enough room to rotate freely
srx700lt
- Mar 29, 2006
- Sweden
- Sweden
- SW XTX-146 SE
I went with Avid 8 tooth drivers and Challenger extreme 64. I use 8 tooth since I wanted a bit more clearance between the track and front cooler.
Mason Sorensen
- Nov 8, 2017
- Iowa
MPI Turbo
Black diamond Helix
Tether kit
SLP Mohawk SKIS
17.5 limiter straps
Stingray Spring
How much was with stock drivers and where did you get the drivers from?I went with Avid 8 tooth drivers and Challenger extreme 64. I use 8 tooth since I wanted a bit more clearance between the track and front cooler.
iwillwait4u
- Aug 30, 2011
- Churdan, Iowa
- 13 xtx nytro stage 1 turbo
Still working out ok? Has it ever hit?Challenger extreme 64 and original 9t 2,86 drivers it just have enough room to rotate freely
