Simmons Flex Ski Question.
There are good arguements for both. Bergstroms says put the biggest and freshest on the inside. Many people have had success both ways. Your choice. There are many posts regarding this. The best way to go is to do a search and decide what is best for you. I put them on the inside and was very happy, although I did not try them on the outside.
Boston is correct,depends on your sled ,studs, riding style,I've always run mine with the most aggresive simmons had .the same inside and out.
Or you can use the same length on both sides like many of us, 6 inchers all the way around.
