KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
You guys shouldn't be shimming the Trackers. When you shim them you take away the reason that they work. The corrector needs to touch the trail up front to provide easy steering and prevent darting.
I tried them shimmed once and it was awful on hardpack. Hard steering and twitchy. Took out the shims and all was well.
Also know that you don't want worn out correctors.
cobrajet ltx dx
- Oct 5, 2014
- pa
- 2015 yamaha ltx dx
I used Bergstrom shims, I believe they were his 1/8inch.How thick was the shim you added?
Never wore out his shims in 8k.
Used the stock Yamaha rubbers. Modified them to fit the curve saddle and screwed them to the bottom of the rubbers.
Also added different washers on either side of the spindle bushing to create a tighter tolerance ( side to side).
Maybe Travis from BOB can chime in because he bought my sled and saw my setup first hand.
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
Travis, how much is a Snowtrackers set up for a 18 Sidewinder LT-X?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Was hoping the offset bushings would get the ski bolt high enough in saddle, but not quite. I have to mill a little material off the pocket of the skis. No big deal.
Basically you just need to trim the stock ribs off the stock ski rubbers and then these skis with my mods will be a direct fit.
I will charge $150 for a good used set of skis. They will be milled down and offset bushings pre installed so that they are ready to bolt right onto a Viper or Sidewinder.
I have Blue, Red, Black loops available.
Snow trackers work excellent on these skis, and I can install them too if someone wants them. $215 for Aggressive and $200 for semi.
