Hi!
Need to replace the drive shaft bearing on the chaincase side and some boggie wheel bearings also. The OEM prices in Sweden are ridiculous - 130 USD for the drive shaft bearing!!
Does someone know the SKF numbers for the bearings? Searched the SKF web site but couldn´t find SKF bearings with the same name as the OEM. Example; the drive shaft bearing chaincase side marked 6205RU.
Also bearing for rear axle midddle wheel marked 6004RK, the idler(?) wheel bearings marked 6205RK and the small wheel bearings marked 6004RD?
Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
erexett said:Hi!
Need to replace the drive shaft bearing on the chaincase side and some boggie wheel bearings also. The OEM prices in Sweden are ridiculous - 130 USD for the drive shaft bearing!!![]()
SKF numbers are the same
6004 2RS could replace the other 6004RK, and 6004RD
whits-end
- Mar 2, 2004
Try UB 205 for the drive axle bearing. You can probably make any '6205' sized bearing work, if it has a locking collar.
