ranger1
After much research I decided to mount the scratchers on the skis. The problem I am having is that I can't find a long, 10mm metric grade 8 bolt which will go through the ski & be long enough to accommodate the scratcher. A 7/16th's bolt is just a hair narrower than the stock ski bolt & it is a little sloppy in the bushing.
To do the job properly I need two 8 grade 10mmx160mm bolts but can't find them anywhere.
Any other suggestions on how I should mount these to the skis?
