Skid plate instructions ?
NY_Nytro
Grand Island, NY
Website
www.gi-snowmobiler.com
I moving my skid plate to my new sled. I fould a store locally that sells those compression inserts but I need to know what size drill bit Yamaha says to use when you drill out the rivets.
It's supposed to be a 10mm but my metric's did not go above 8mm. So a 13/32 works perfect. I also did not have a drill stop that big so I used a washer and ductape. YOU MUST USE THE DRILL STOP. The drill will fly up in ther fast and cach something. Tip#2 add a drop or two of oil to the threads on the tool and the threads on the compression fitting. It can keep you from stripping one out. Doug
HANDY HINT..........do not over tighting the screws that hold the skid plate in,you will destroy the treads on the outside of the inserts.Install new ones to solve the problem.
Where can I buy the compression inserts , I have 1 that wont stay in
thanks
