Daranello
Suspended
Tool, what tool.....I just hammered mine back in
KevinS
Daranello said:Tool, what tool.....I just hammered mine back in
It will pop out again. Water drips down into the skid plate and when it freezes it expands and forces those rivnuts to pop out of their holes.
gitrdun
- Mar 15, 2007
- north of superior
- 07 Attak
Daranello, I agree with KevinS, give yourself a tap with that hammer and do it right, or you'll be carrying your skid plate home in the packsack.
Mikecam
Basically a bolt and a nut. The bolt threads into the rivnut and then you lock it in with the nut. As you increase the pressure the rivnut will squish inside the hole and keep it from being able to fit thru the hole. It sometimes takes a lot of pressure and some seem to go easier. The one I had pop out looked like it hadn't been squished at all. I put it back in and squished it good. 2000 miles later and one oil change and she still is tight as ever.
Daranello
Suspended
Ah so the supose to mushroom inside, mine that pop out look new.
So are you saying torque that screew tight???
gitrdun
- Mar 15, 2007
- north of superior
- 07 Attak
Expand in the hole is only half of the solution. It also has to form a flange on the backside and if the rivnut isn't long enough in the first place, it won't do that when you reinstall it. Chances are if you had trouble with one, more will follow, so replace all four with the 17.27 mm AVK aluminum rivnut...or one of the other fixes that other guys have mentioned.
Mikecam
The alum. plate that the rivnut is going into is only 1/8 inch think. The rivnut should work up past 1/4 inch material or a little more. Yes Daranello they should mushroom inside. If yours looks like new then it didn't mushroom and yes you can still install it. But it's not just as easy as tightening up the screw. You need a bolt and nut to do the job. The bolt pulls the rivnut and the nut holds it so it mushrooms. Just putting the skid plate on and tightening the screw will not do it. Basically with the special tool you can mushroom the rivnut with out having it even installed.
The rubber wellnuts which is what they are called will work, I have them on my R1 but when you over tighten them even a little too much the brass nut turns in the rubber and the rubber rips from the brass nut then it just spins when you try to back them out.
Daranello
Suspended
where can I get that special tool???
STILLCRP
- Dec 11, 2006
- DECATUR,IL.
- 07 Attak
SPECIAL TOOL
WHEN YOU BOUGHT YOUR SKID PLATE IT COME WITH EVERY THING YOU NEED TO PUT IT ON. THERE IS A COLLET AND LONG BOLT THAT YOU SET EACH FASTENER WITH YOU REALLY HAVE TO CRANKEM DOWN TO SET THE SHIELD PROPERLY THEY DO NOT TELL YOU THAT IN THE DIRECTIONS I
PUT MINE ON MY ATTAK DID NOT HAVE ANY TROUBLE BUT I REALLY CRANKED THEM DOWN. GARY
STILLCRP
- Dec 11, 2006
- DECATUR,IL.
- 07 Attak
SORRY DID NOT READ YOUR FIRST POST.SIMPLE TAKE IT BACK TO STEALER MAKE HIM FIX IT . GARY
drewfus04
A lot of people get their skid plates online instead of through a stealer and there is no special tool or installation hardware.
Self tapping screws and two bolts in the front worked great for me and have passed the test.
My father ran into a 3' rock @ 50mph with just scratches to the skid plate. The thing didn't even move.
Besides, it just seems simpler when the time comes to change that oil again.
Blue Oval
- Feb 22, 2006
- Westminster, Ma
- snyderpools.com
Well said! This IS exactly what I diddrewfus04 said:A lot of people get their skid plates online instead of through a stealer and there is no special tool or installation hardware.
CaptCaper
- Jan 1, 2007
- Northern N.H.
- 2016 RS Vector XTX 1.25 Lug .2013 RS Vector LTX. Past Machines 3-2007 Attaks 1-2010 Vector LTX.. 2- 2003 VMax 600ER's.
- New Hampshire
What size self tapping? #10 ? #12?
drewfus04
I'm not exactly sure off the top of my head. I'll check into it and get back to you.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
When I installed mine I put JB weld on the Rivnuts. That should help them stay in.
