skid/ra cable questions
dexter
Maine
Yanked my skid out of my new to me 10 ltx and I have a couple questions as I am new to the mono ans ra set up.
How do I disconnect the ra so I can paint the w arm?
See in the pic where there is a holder for the ra boot that is not used. Is this right or should I disconnect the ra and route correctly through the 2 hoops? Notice the wear on the top off the ra adjuster. How do I avoid this?
Lastly. .notice the gap on the bottom mount of the w arm...is there supposed to be a bit of side to side play?
wanted info on ra before they told me find a setting and throw cable away they get full of ice and snow and break lots
To disconnect the RA simply unscrew the cable end from the shock. Remeber the setting on the RA dail to ensure correct setting and control of the RA when re-assembling.
The wear on the top of the plastic is from the track. Designed exactly for that.
The RA boot is routed correctly as per pic. The upper loop/holder is to protect the boot.
