sled stalling
farmerschiferl
Age
33
Hewitt,WI 54441
2017 Yamaha Sidewinder BTX-LE
LOCATION
Hewitt, WI
2014 viper xtx has the latest flash, runs good but it randomly dies, turn off the key and it starts right back up with no problems i've checked the tps sensor in dig mode all seems good. looking for other people's thoughts on what to check
Belt deflection too tight?
My 14 did that several times at wot almost threw me over the bars. Once at 116 mph. Ulmer has had the sled for 3 years now so I have not run it to see if it still does it.
Adjust throttle cable freeplay, TORS is probably acting up
Interesting
Sent from my XT1650 using Tapatalk
That is exactly what my sled used to do; if I remember correctly the dealer said there was some "hard" grease in the throttle, and after they cleaned it, it never did it again. Apparently it effected the operation of the throttle's "kill switch".
Mine did the exact same thing. Everything looked fine in Diagnostic mode too. I moved the throttle cable around near the zip tie and it went away. I think that zip tie was the problem so i put a new one on with a lot more slack. Its been fine for the last 1000 miles .
Mines been stalling when i coast to a stop, and it just started this season after my turbo install, also noticed a touchy throttle and a little bit higher idle.
Diagnostic's and tors is where it should be, ill try checking the throttle cable routing.
Did you check tps in diagnostic with handlebar cranked to the left and cranked to the right also?
Mine was good until i cranked left
yes checked it both ways cranked as far it goes seemed normal goes to 100% then right back to 0 when i let off
Hi. I'm Sydney's dad
And we purchased this sled from you this weekend. You said good running condition. ( friday 3- 9-18) on this day she had issues with it stalling. 6 or so times. On Sat. It would not start. We asked you then if you have had issues. You said
NO. My brother eventually got it to run that day. On Sunday it would not start again. I see here that there have been issues. What gives.. Be honest. Waiting a reply on this.
WOW. I hope the seller steps up. Good luck.
Who is Sydney and who in this post did you buy the sled from?
