sledheadgeorge
What kind of mileage you guys getting on a set of sliders? Noticed on the 137, with just the hub and no 4th wheel kit, that they wear fast at the back. Are they like the Apex where it wears to a certain spot and stay for a while?
number1kyster
My Dad has the Stealth Big Wheel Kit. 6,600 miles on his sliders.
rlbock
I have the 4 big wheel kit and the only wear I’m seeing is up front just in front of the outside boggie wheel, it seems to have worn down to just above the bottom line and has stopped wearing. My sled has 2900 miles on it and these are the original slides
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
By far best sled ever on slide wear for me. Still all looks new with little to no wear(129") near 4200 miles now.
Dan
Dan
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
I've got 3,600 on mine. Wear in the rear to the line and in front of bogie wheel like above. They wore to this spot and then stopped. Clips all look good. That said I have a set of duponts that will I put on prior to next season. I do have the 4th wheel.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
5k. look good
mooser17
- Jan 10, 2017
- Muskoka
- Sidewinder ltx le
8000km on Dupont slides they virtually look new. Ltx le
DennyTuna
- Jan 28, 2017
- Ohio
- 18 Winder LTX 50th
16 SR Viper RTX (red)
02 SX Viper ER (red)
97 SX Vmax 600 (red)
Like Dan's here, 4100 miles and still like brand new. I do have the stealth big wheel 4th wheel kit on though.
Flipper
- Oct 31, 2003
- Ottawa, ON
- 2018 SideWinder LTX LE 50th
- Ottawa
Second season on mine and they look really good. Closing in on 5K.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Stock original sliders and just Yamaha optional stock size 4th wheel kit on LTX and sliders in excellent shape at 4000 miles.
I went to put on the Duponts this last fall and asked myself why. They looked worn in back on the outside from the clips wearing off the outside some, but once I got a real look at them it was evident on the inside of the slide where the clips are not wearing that the sliders were still like new and not worn as I had thought, so why install the Duponts, put the original ones back on. They haven't worn a lick since.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I changed mine at 6000kms just because, they wear to a point and that's it. I have over 10000kms now and I'm sure the originals would have still been ok. I wouldn't waste your money on the duponts. My 2 cents.
Sidewinder Bob
- Nov 20, 2016
- Remsen, NY
- (2) 2017 Yamaha Sidewinder Ltx le
2017 ltx with 5400 miles, wear at the bend.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
These sleds are great on sliders. I like the slippery ones from Wahl brothers racing. They are like 100 for a set but worth it IMO. Been running them since 2012 on the procross chassis.
http://www.wahlracing.com/Super-Slippery-Slides.html
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Has anyone removed their inner idler wheels entirely?
My inners(129") tend to last 1200 miles then chunk off due to studs. When i look at things, it looks like i could easily remove the inners entirely and still do fine on slider wear between the existing outers.
Sure would be nice, as the outers last forever without running over stud heads.
Dan
Dan
sledheadgeorge
Reason I asked about slider wear in the first place...is that sliders were worn to this point previous check. Then I rode another 1000 miles and they seemed to stay in the same spot. This set has 3000 miles on.
Don't get me wrong, I will change them, however just asked so I have a good idea of what going on with slider wear.
