bigdave
- Dec 18, 2003
- sylvan lake, Michigan
- 14 Viper LTX SE, 14 Viper RTX SE , 08 FX Nytro , 07 FX Phazer, SOON 2017 Sidewinder LTX LE Blue
As i was studding the 05 RX1 ER i noticed that when i moved the track back and forth the gears would clunk is this normal for a reverse sled I have never owned one just want to feel at easy with this thing.
JDKRXW
Sounds like your chain is loose. Tighten it up and check the slop again.
PARX
I had same thing, hand tightened chain, still loose, called dealer & yes this is normal & with reverse it is worse, he said nothing to worry about
bigdave
- Dec 18, 2003
gear slop in rx1 er
Thanks guys I did tighten the chain with no change in slop!
this makes me feel better to hear that the dearler told you it was normal as i have no exp with reverse
Thanks guys
Thanks guys
- 11K
