SLP slt skis
GT man
I recently ordered the ski-doo pilot skis for my apex gt but i'm very concerned about the problem some guys are having with their durability.I don't want anything that is harder to steer and was wondering if anyone has tried the slt skis on an apex and what your feelings were about them.
GT man, Why trade one oem ski for another? Generally,The best aftermarket skis are much better than oems. Depending on what handling characteristics and application your looking for; C&A, SLP,USI,Simmons and SLYDOG all have great skis. The negative is , you have to do your research to find what's best for you.Studdog
apex gt 4 stroker--- did you use the slts or the powder pros---- if you used the slts what carbide set up did you use and how hard was it to steer
Comparing apples to applesauce, but after trying several different options, SLT's SLP skis were one of the single best things I've done to my '03 F7 in 9500 miles! – Roy
I tried them both.
RoyT and X-ape tell me more. what carbide did you use? X-ape, did they work for you or not. I need to make a decision asap--- GT man
Both tests I used a 3/16" shimmed snubber. I found little difference with the pilot as the center keel is in charge on hard pack....just like the stocker. The SLT with the mount all the way back worked well. The darting is still detectable while declerating hard with brake at high speeds and on tracked up hardpack. But with the SLT it was managable and acceptable. You must realize that its hard to offset the weight that sits over the skiis on the apex, especially with the mono and its lack of center force adjustment. My carbides were slightly worn 5" trailblazers.
