maddogjeff
- Mar 27, 2005
- Ride northern Vt & QC, live in Ct
Got 900 miles on my SLP Anti-wear Pads and the verdict is ---------- they frickin work - SWEEEET. Have an 05 RS Venture and after 900 miles have only lost 1.5 mm of hyfax. Last year on 3 different sets of hyfaxes I had lost over 5mm of hyfax at 900 miles. I know, I know that I've made posts telling everyone to be patient, that the slides start to last a long time after 5mm BUT WHO HAS THE PATIENCE - GET the anti-wear pads boys and get some peice of mind.
This only proves that Comoplast or Yamaha is at fault in the design of Ripsaw track. Who do I send the bill to?
3 sets of hyfaxes - $90
Labor to install - $90
Anti-wear pads - $27
Labor to install - $50
Wear and tear on the brain - $50,000
bluecheese
I put the anti-wear pads on and rode with them for the first time last week. I went 200 miles and the hyfax look like brand new! My last set of hyfax only lasted 98 miles. Big improvement and well worth the $20 investment.
Tfin
Do these come as a "kit" or do you have to order the exact number you need/want?
maddogjeff
- Mar 27, 2005
Starting Line Products 208-529-0244
http://www.startinglineproducts.com/
Part # 25-102 Anti-Wear Pad Kit 40 Pak
Part# 20-160 Track drill 1/4"
06vectorgt
Part # Description Retail
20-160 Track Drill 12.12
25-101 Anti Wear Pad Kit per each: 1 pad, 1 washer, 1 nut 0.74
25-102 Anti Wear Pad Kit 40 pack: for 136/144/151" tracks 29.60
25-103 Anti Wear Pad Kit 32 Pack: for 121" tracks 23.68
25-104 Anti Wear Pad Kit 42 pack: for 159" tracks 31.08
25-105 Anti Wear Pad Kit 44 pack: for 166" tracks 32.56
Tabor Rider 973
- Feb 3, 2005
- VT
- Yamaha Venture
I used a 1/4 regular drill bit and it worked fine. I'm glad you guys are getting some test miles in. Not much riding in Vermont.
Tfin
Great, thanks for the info guys. I think I'm going to get myself setup with these anti-wear pads.
cobra93302
Tabor Rider 973 said:I just put in SLP pads along with a set of Hiperfax last night.
Do you need to put Hiperfax on or can you run your factory hifax with the SLP pads?![]()
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
- www.gi-snowmobiler.com
cobra93302 said:Tabor Rider 973 said:I just put in SLP pads along with a set of Hiperfax last night.
You can use the SLP pads with any hifax, but Hyperfax requires a fully clipped track or SLP pads.
cobra93302
Thanks NY_Warrior for the info. I think I will order a set for the rage so when it snows out I will be ready to play in the snow.
maddogjeff
- Mar 27, 2005
Put another 900 miles on in great snow conditions and didn't lose any hifax with my SLP pads. That's 1700 miles and only 1.5mm lost, at this rate I should get 9,000 miles on this set of faxes.
myyamaha
does any one know if U can get them from part unlimted ?
maddogjeff
- Mar 27, 2005
Dennis Kirk and Hi-performance have them in their catalogs.
Ole Timer
How many do you need for a 121" track ? Do you put them in every slot or just in between ? Thanks
Groomerdriver
was gonna open up the holes with a hot razor knife tonite but the wife's going into work tonite
oh well..somebody haz to pay for my toyz!!!
as also going to put in the 2" clutch guard vents like Yama Crazy did - real simple install and will really help in cooling down the clutch!
