Also remember these engines have a system to reduce engine braking. It does this by opening the IACV which means it goes lean on deceleration. That can make the popping too.Hey Jeff, I am finding I have the backfire when I hammer the throttle. I just did the new ECU flash and I was blaming it for that but I was told that it could be a crack in my header or leak.
ApexGTman
- Jan 8, 2006
- Newfoundland
- Hers - 2017 Sidewinder XTX LE
His - 2015 SR Viper RT-X LE MPI Turbo with Ulmer Stage II Clutch Kit
2012 Apex SE
2006 Apex GT, Stage 2 Ulmer Clutch Kit, Ulmer Stealth Mod Air Box, 144 1.325" Woody's
2003 - RX1
1998 - SRX
1993 - Exciter SX
1992 - Exciter II
But mine does not get it on deceleration, but rather when I hammer the throttle.Also remember these engines have a system to reduce engine braking. It does this by opening the IACV which means it goes lean on deceleration. That can make the popping too.
Oh. That is different. Must be a leak or really rich.But mine does not get it on deceleration, but rather when I hammer the throttle.
jeffgilbert
- Dec 17, 2007
- Newfoundland
- 2019 Sidewinder BTX LE
Do you have a PCV ignition module?But mine does not get it on deceleration, but rather when I hammer the throttle.
ApexGTman
- Jan 8, 2006
- Newfoundland
2012 Apex SE
2003 - RX1
1998 - SRX
1993 - Exciter SX
1992 - Exciter II
????Do you have a PCV ignition module?
jeffgilbert
- Dec 17, 2007
- Newfoundland
You probably don't have one on it then I had a trouble with the one I installed on my sled backfired at wot
