Wannaviper
- Mar 18, 2014
- West Gardiner, Maine
Thank you, I will check out the Trackers on your website! Out of curiosity, did you make any adjustments to the skis prior to installing the Trackers. I know that there has been a lot of discussion about adjustments being made. I can't speak to the Trackers on my Tuner skis because those were dealer installed; however, I have installed Trackers on a Vector, a Viper and a Sidewinder, both with Cat skis, without any adjustment, and they have all performed perfectly.I have semi aggressive in stock for the stryke ski.
The stud pattern is the same but the stryke ski requires longer studs as you mentioned.
I ran the semi on my 21 stryke skis last year and they worked great as I expected.
21GT
- Mar 3, 2021
- Michigan
- 21 Ltx-gt
I just installed the aggressives on mine and the instructions said to make certain the Ski toe is adjusted to 0°. That's what I did on mine but have not ridden yet to give any feedback on itThank you, I will check out the Trackers on your website! Out of curiosity, did you make any adjustments to the skis prior to installing the Trackers. I know that there has been a lot of discussion about adjustments being made. I can't speak to the Trackers on my Tuner skis because those were dealer installed; however, I have installed Trackers on a Vector, a Viper and a Sidewinder, both with Cat skis, without any adjustment, and they have all performed perfectly.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Like 21GT said set the toe to 0. I have set both single keel ski sleds I put Aggressive SnoTrackers on to O with slight tension between skis and this has worked wonderfully.
21GT
- Mar 3, 2021
- Michigan
- 21 Ltx-gt
Just wanted to give a update on this thread. I installed the aggressive snowtrackers on the stryke ski and followed the instructions on install. I put 100 miles on them between hardpack trails and fresh snow trails. They handled flawlessly 0 darting and the steering was sharp light and precise. I am happy with my choice thanks to everyone on the forum that helped me out.
