SharkAttak
CaptCaper said:SharkAttak said:CaptCaper said:Shark I'm an custom upholster of 35 years On the Cape. I'm in NH now but go down there all the time getting and doing automotive,boats,etc. and if you want to save money go to an upholster and buy firm foam of good quality and put it in your self. WalMart's don't have good foam. It'll flatten right out. Go limp. Take the old foam in to compare..There is lot's of frim,extra firm foam out there. Depends on what you have now and what you want.
Take the seat over off measure how thick and long the foam is. You can glue the foam into a block that can be cut down to shape with an electric knive..(turkey carver) Put a piece of Dacron from Walmart on it to hide any cut marks. Pull seat back to orignal place and staple back down.
Use the carver to take the old foam off if it's glued to the plastic. Run the knice along the seat were the foam meets it. If you try to pull it off it will rip if it's glued good. Sort of a scalping action..Use the old foam piece as a guide or save to put back in case you change your mind.
Use 3M Fabric and Foam Cement to glue foam together and dacron to foam.
Simple just some carving skills. I'm going to shape mine out to make it longer and wider at back. I'm tall and hit the plastic stop inside just befoe the storage flap..
Any questions just ask..
Thanks CaptCaper, where on the Cape was your shop? where in north N.H. do you live now?
Onset near the beach....for the last 25 years.. I did charter's out of Hyannis and Chatam commerical fishinng from Plymouth,Sandwich,Ptown, in the summers. When work was slow. My neighborhood went to heck so I moved to Mirror Lake Whitefield NH..on a trail. I'm trailmaster here and I still go back all the time to get work anywhere from Boston to Ptown. I use the VNose SnoPro to haul the stuff![]()
Onset is real nice, Cape Cod is awesome in the summer, but alittle boring in the winter, i'm from Falmouth,Ma. but during the winters i go to Colebrook,NH, thanks again for the advise
