Albinsson
- Jan 16, 2017
- Hälsingland
- Sweden
- 2010 FX Nytro Rtx/Xtx MCX 180
Hi
I´am also looking for a softer take of with my turbo nytro.
Just to be sure to order the right thing i want to ask the following question.
When you say "YPY short" spring, is this the right part number: 90501-582J1-00. (From the "short cover primary spring" table in the tech section of ty4stroke)
And is this the only part needed? Or is there additional components as shims that needs to be ordered?
Also, do I need a puller to do the job, or do I only remove the spider with normal wrenches from the garage?
cheers, and thank you for a great forum
bullit01
- Feb 5, 2016
- North Bay
- 2008 FX Nytro
No you do not need a puller. you can do it with the clutch on the sled. Just unbolt the cap which has 6 bolts, there will be some spring pressure so push on the cap as you are unbolting. loosen them evenly and notice the x under the cap to realign for balance. remove spring and reinstall.
04mx
- Oct 20, 2015
- canada
- Yamaha
so there is a ypy long spring and a ypy short spring ?
bullit01
- Feb 5, 2016
- North Bay
- 2008 FX Nytro
Yes. your clutch will take the long ones.
Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
I just ran the BOP soft start spring in my Apex up in Munising, MI. I'm very pleased with the lower engagement and the sled still pulls hard! If there's any loss of performance; I don't notice it, but I'm not a super aggressive rider either.
Long story short...this spring is staying!
bullit01
- Feb 5, 2016
- North Bay
- 2008 FX Nytro
what is your engagement coming in at? These things make a lot of torque in the bottom end that's why they can pull from low engagement. I'm thinking of making mine engage at around 2500 to 2800rpms. less track spin on take off. has anyone tried engaging that low and what spring did you use?
Redbeard
- Oct 14, 2011
- IN
My Apex is engaging at 2800 ish rpms with the soft start spring.what is your engagement coming in at? These things make a lot of torque in the bottom end that's why they can pull from low engagement. I'm thinking of making mine engage at around 2500 to 2800rpms. less track spin on take off. has anyone tried engaging that low and what spring did you use?
bullit01
- Feb 5, 2016
- North Bay
- 2008 FX Nytro
does it have the preload rate info on that spring? is it a 30-113 or 20-119?
bullit01
- Feb 5, 2016
- North Bay
- 2008 FX Nytro
I'm going to order the Yamaha 20-119 spring to see If it will engage at around the 2800 rpms. the stock spring has a pre-load of 35 and the one I am ordering is at 20 pre-load. this spring is a Pink-Blue-Pink.
Redbeard
- Oct 14, 2011
- IN
There is no pre-load information marked on the soft start spring.
bullit01
- Feb 5, 2016
- North Bay
- 2008 FX Nytro
ok Thanks. I am going to try the Pink-Blue-Pink and see what it engages at.
bullit01
- Feb 5, 2016
- North Bay
- 2008 FX Nytro
Just installed the Pink-Blue-Pink and it engages at 2900 RPM's with stock weights. Its 20 pre-load and 119 full force
marioandretti
- Dec 17, 2020
- Ont
- '16 Viper LTX-LE
Bring an old thread from the dead here...Just installed the Pink-Blue-Pink and it engages at 2900 RPM's with stock weights. Its 20 pre-load and 119 full force
Bullit01, there is no “pink-blue-pink” listed in the previously posted spring table/chart...
What is everyone’s preference for soft springs?
cheers
zx4ever
- Apr 14, 2011
- Northern BC canada
- 08 nytro ty4stroke customized
I use the orange pink orange spring with 14.5 rollers it starts off really smooth.Bring an old thread from the dead here...
cheers
marioandretti
- Dec 17, 2020
- Ont
- '16 Viper LTX-LE
Thx. What sled is this on?I use the orange pink orange spring with 14.5 rollers it starts off really smooth.
I have read that rollers don’t necessarily need to be replaced.
