Augie
- Sep 2, 2016
- S.WI
- 98 700 VMAX
06 ATTAK
20 X2 XTR
21 RMAX2 LE
24 YXZ XTR
Looking for better engagement on my Attak, anyone out there use pink blue pink spring? I'm aware Of the BOP soft start spring but I can pick up The Yamaha spring local for half the price
Smokum
- Jan 31, 2011
- Prairie du Sac WI
- 2011 Apex XTX, 2003 RX-1 MTN
BOP spring here. Well worth the money if the other one doesn't pan out.
May I ask "what" is the engagement rpm using the BOP primary spring? Thanks!
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Typically 25-2600 rpm depending how clean and free your clutch is.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
At least if you buy mine you know you will get the results you are looking for!
That is a significant reduction! Thank you for posting the info.
Augie
- Sep 2, 2016
- S.WI
- 98 700 VMAX
06 ATTAK
20 X2 XTR
21 RMAX2 LE
24 YXZ XTR
Already been delivered from you, thank youAt least if you buy mine you know you will get the results you are looking for!
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Will the BOP soft spring work well on a 2013 Apex?
