GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
How smart is that controller? Does it know about the difference between battery types (float voltage, maintenance, etc)?
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
Not likely very smart. It has worked well on my Yuasa AGM batteries for about 3 years now. Keeps the battery topped off between rides.How smart is that controller? Does it know about the difference between battery types (float voltage, maintenance, etc)?
mattison
- Mar 12, 2019
- RI
- 2010 RS Vector, 2011 Apex SE, 2016 Apex LE
Do you tow with panel on the mast or is it removable for travel?
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
Remove for travel. Three bolts hold the mast on, (pipe hanger clamps) and the bent section is a satellite dish mount bracket that slips into the vertical pipe. This dish mount and turning the pipe allows you to adjust toward the sun in two axes.Do you tow with panel on the mast or is it removable for travel?
