Just take time to make sure the suspension is adjusted to your liking, and if it isn't take the time to make it right. It's worth the effort.
Be sure the ski's are toe out just a bit, many arent, and the '08's can be a bit dartier than the newer ones.
As far as thing to watch out for? IMO, the '08 subframe, which can be modded easy enough to be very strong. The tunnel could use a block-off plate and if you don't run studs, ditch the tunnel protectors. It has a deep enough tunnel anyway, but the protectors being gone with a block off plate with cut the snow build-up down tremendously!
