Turboflash
- Mar 18, 2019
- Southern MN
Ever since the 1st year (2017) what I've read and heard is Yamahas had about a 3-4 MPH higher top speed than Cats.21/41= 1.95 ratio srx
24/50=2.08 ratio thundercat
i know what this means on a car but what is the real final ratio after the drivers and clutches and track height
how much mph will this alone knock off
and will this be harder on belts
just say with stock 1 " 2 ply track studded 144 for now
Top speed difference between these 2 ratios (according to Cat Service Manual - Cat clutching) is 21/41 ~ 123 MPH. 24/50 ~ 115 MPH, both at 8800 RPM engine speed.
The higher ratio (2.08) (which is really a lower gear) will be easier on belts.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
The SRX (21/41) is about 6-7 MPH faster than the T-Cat (24/50) on paper which is likely the real world as all other factors are equal.
Taking gears only into account.
| Gear Ratio Calc | Top | Bottom | Calculated | Ratio |
| SRX Stock | 21 | 41 | 0.51 | 1.95238095 |
| TCAT | 24 | 50 | 0.48 | 2.08333333 |
| Choice 1 | 22 | 41 | 0.54 | 1.86363636 |
| Find other gear ratios | 25 | 46 | 0.54 | 1.84 |
| Top Speed Calc | ||
| SRX Stock | 123.46 | |
| TCAT | 115.70 | |
| Choice 1 | 129.34 | 22/41 |
Turboflash
- Mar 18, 2019
- Southern MN
Question is, how far do you race out front of your favorite watering hole?
Most guys rarely race for top end. Usually it's from dig to 1000' or maybe 1250'. The 24/50 may be faster to 1/4 mile than 21/41? If you're gonna bar race from 30 mph roll to 1/2 mile stake, then likely the 21/41 would prevail?
SledFreak
- Feb 7, 2005
- Ontario. Canada
On a open spot on a hard packed groomed trail (1400 feet), my sled will hit 118-120 on gps with the 240-270-300SStune. It just gets there faster on the higher tunes. I run this same strech of trail alot during the year and the results are the same. Stock 1" track came on the 2020 TCATS with 24/40 gearing. If you look at alot of shootout results from prior years the CAT beats the SRX and most of the time and the reason is because of the gearing.
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
If you get a non silent drive full clip 1.25 track you won't lose any mph. Fact.
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
I'm a big fan of the 24-50 in my 2020 winder with 240ss tune. Good for tight trails and 115mph at 8650rpm gps last year on hard packed lake. May have had a bit more in it.
blown apex
- Jan 29, 2006
- ALTON ILL.
- ristermotorsports.com
on the srx 137 how many have removed the adjuster block completely for more transfer
i read it some were
is this bad in any way
i read it some were
blown apex
- Jan 29, 2006
- ALTON ILL.
on this graph from 40 up the grey graph looks faster every were or is this a rpm to mph exampleThe SRX (21/41) is about 6-7 MPH faster than the T-Cat (24/50) on paper which is likely the real world as all other factors are equal.
Gear Ratio Calc Top Bottom Calculated Ratio SRX Stock 21 41 0.51 1.95238095TCAT 24 50 0.48 2.08333333Choice 1 22 41 0.54 1.86363636Find other gear ratios 25 46 0.54 1.84
Top Speed Calc SRX Stock 123.46TCAT 115.70Choice 1 129.3422/41
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
It’s rpm to mph which of course has lots of dependencies (clutching,hp,traction,etc).on this graph from 40 up the grey graph looks faster every were or is this a rpm to mph example
hellflyer
- Dec 2, 2008
Its fine to remove the block completely! I ran it for a bit that way but I think the trail ride suffered a bit with more transfer even though it was fun I be able to lift the skiis a bit more!on the srx 137 how many have removed the adjuster block completely for more transfer
i read it some were
finnpowersports
- Nov 23, 2014
- Northern NY
- '23 SRX LE; '22 Assault 850; '22 Enduro 600R; '23 Rave RE
I ran my 2020 SRX this way all last season with no issues. Mind you, it was stock, no tune, and I weigh about 175 lbs.on the srx 137 how many have removed the adjuster block completely for more transfer
i read it some were
Definitely was a huge improvement for weight transfer and personally, I didn't feel that the ride suffered much at all. Handling did a bit.
I tried it and didn't like it. Couldn't control the sled when I wanted to put the hammer down and carve trail.on the srx 137 how many have removed the adjuster block completely for more transfer
i read it some were
However, it's more of a personal choice as some guys like it when their skis are in the air. (doo guys)
The suspension will bottom easier with them out and it tends to be harder on the front torque arm.
hellflyer
- Dec 2, 2008
That's what I found ! It bottoms easier on the big slower whoopsI tried it and didn't like it. Couldn't control the sled when I wanted to put the hammer down and carve trail.
Turboflash
- Mar 18, 2019
- Southern MN
On 137" skid, you can get better weight transfer by either turning up center shock spring or replacing it with Stingray spring. The center shock then becomes stiffer and more of a fulcrum point. I didn't think it hurt handling at all - actually better when on brakes hard, sled doesn't nose-dive so bad.
