fourload
Talked to my dealer this morning and he confirmed what we all knew about the new skis,track,front end and eps. He also mentioned that his rep said the motor was the same but it had variable intake tuning and a few other tweaks for more hp. He didn't know how much more however. The rep did say the sled was lighter , quicker and faster than our current Apexes .He also said there will be an Apex offered with a 144inch track and tipped up rails.
SharkAttak
fourload said:Talked to my dealer this morning and he confirmed what we all knew about the new skis,track,front end and eps. He also mentioned that his rep said the motor was the same but it had variable intake tuning and a few other tweaks for more hp. He didn't know how much more however. The rep did say the sled was lighter , quicker and faster than our current Apexes .He also said there will be an Apex offered with a 144inch track and tipped up rails.
good info, thanks
MT RX1 Mountain Man
Anything about an MTX version? Will they still have one?
T-Bone
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
T-Bone said:From Sled Talk. Thanks CR for more teasers!
How can that Delta box be lighter than what we have now? Looks like it was sent to China for the cheap labour to make it that way!
Is that a servo-motor I see there?
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
looks like a power valve servo off of a viper.
fourload
Same pink secondary spring..... Does anyone know how the variable intake tuning works? The R1 bikes have it. If it has variable intake tuning does that mean it is drive by wire too???
Inquiring minds want to know......
It's Has "Exhaust Ultimate Power Valve (EXUP)"
SharkAttak
fourload
That does look like a servo that could be used to control an EXUP. Maybe my dealer didn't hear his rep right and it is a variable exhaust or maybe it has both intake and exhaust like the precrossplane R1 engine.
apltx08
The clutch system seems the same...that servo could be the DRIVE BY WIRE! for throttle control.
cat hunter
I hope they make a GT model with the clicker shock up front!!!
MOOSE
- Feb 28, 2008
Wow! fox float up front!!! Is that a picture of my Apex XTX SE.....?
fourload
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
It looks like a gear reduction as well, judging by where the crank should be and where the primary is.
