Pbadgley
- Feb 16, 2011
- Inuvik NT
- 2004 Yamaha RX Warrior
Was enjoying boon-docking is some fresh 2ft of powder
when I developed a light noise from under the hood
. I stopped to check and everything looked okay
. I decided to head back home and the noise kept getting louder,
like a gear not meshing properly. I stopped and checked again. The sled would go into reverse okay and no noise in reverse. I went on my way again
and the noise continued. I had no choice but to limp it home. I got back onto the hard packed trails and the noise was not so loud now. I let off the throttle and the noise stopped. I hit the gas and the noise was back.. So now the noise is only under acceleration.
I got back home no problem but still had the noise. I went to put it in reverse to back it in to the garage and now the reverse is jammed.
I cant even pull the lever back to get it into reverse. I checked the gear oil and it was full but I noticed a few specs of metal in the oil.
Any pointers before I tear into the chain case?
check the adjustment on the reverse linkage. sounds like it could be out of spec.
Indy
check the chain tensioner
Pbadgley
- Feb 16, 2011
- Inuvik NT
Well I finally got time to tear into the chain case. The reverse gear needle bearings were disintegrated. Everything else was as tight as a button.
Do I have to take the all the gears off to get the inside reverse gear off of can I slacken the chain tensioner enough to slide the gear off.
Indy
its possible . . . but will make the job harder.
- 17K
