Chris Hammer
- Dec 26, 2020
- Sydenham
- Rx Warrior 1000 cc LE 2004
Just wondering if there is a tester you can plug into the coil wires to see if you have spark? Sled is a 04 Rx1 warrior.
Getting 0 ohms resistance but book says .20 to .25 I think.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Saves taking the plug out and grounding on the engine cover and trying to look for the spark from the plug . Real easy to hook up , and easy to tell if it is sparking .
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Chris Hammer
- Dec 26, 2020
- Sydenham
Thanks, have seen these before and will habe to give it a try. Sled caught on fire and I am in the middle of fixig it back up. I pug in a good new used wire harness. I am pretty sure the coils are done. The tester would be great. I guess I could use a wire light tester to check for power at the plug. How are you uploading the pics here? I always get the message saying the image is to big.
RobX-1
- Coldwater, OH
Most likely your pictures were taken from a phone where the resolution is high which in turns creates a larger file-size picture. A trick I use is to use Windows Snipping Tool. Open picture on your computer and then launch the Snipping Tool and snip and save the image. The new file will be much smaller in file-size and then can be uploaded. If wanting to do this from a phone, there are apps that will also resize your photos and then you can upload directly from your phone.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
This device is great especially if you are alone and have to pull start the sled , as it makes it so easy to see the light .Thanks, have seen these before and will habe to give it a try. Sled caught on fire and I am in the middle of fixig it back up. I pug in a good new used wire harness. I am pretty sure the coils are done. The tester would be great. I guess I could use a wire light tester to check for power at the plug. How are you uploading the pics here? I always get the message saying the image is to big.
It seems everytime I try to add a pic , it is different .
This time was the easiest ever as I just copied it off a website and added to my reply, all on my laptop.
Usually I need to save it in my documents and then upload it to my reply.
Chris Hammer
- Dec 26, 2020
- Sydenham
Chris Hammer
- Dec 26, 2020
- Sydenham
Thanks @RobX-1 for the help! I will try this tool you are talking about!
