spark plug problem with vk 1000
wayne
engine shuts down until I change spark plugs, it then runs fine. when it happens again I can replace plugs with the set that were there before and it runs again for awhile... It seems like that each time a different plug gets fouled.... Any ideas???
Turn off the choke as soon as you can whenever you use it. Excessive choking will lead to fouling. Make sure the plug boots are on securely. Make sure you're jetted correctly for your altitude and weather conditions, and that your carbs are clean and synchronized.
