Pabstkiller
- Oct 20, 2021
- Rothschild Wisconsin
- 2006 apex
Dose anyone have a link to a decent video that shows how to replace the speedo side driveshaft bearing?
Elton Buss
I don't know of a video that shows that process, but it is not difficult. You do not need to remove the suspension or take apart the chain case. If you want to try it I could walk you through it.
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
earthling
Mr Sled the site owner did a video on track change which includes how to access the speedo bearing. Its 4 nuts and there is a set of hex set screw on the backside collar. If you are lucky, it can be done with only pulling the secondary. You can access the set screws from under the sled by rotating the track into position for each screw.
