Yamasledder
- Mar 7, 2010
- Brandon, Manitoba, Canada
- 2020 Viper LTX SE
Hey all. I bought a used 2014 Viper RTX a few weeks ago. I finally got a first ride today. I can't believe how far the speedo is out. With it showing 62 mph its actually doing 86 mph. The previous owner had told me that all updates had been done on it whatever that means. It has just under 1000 miles on it and I know it has never been apart in any way. Any thoughts on this?
Thanks.
Thanks.
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
If he had the latest flash done to the ECU it may need to be redone. Some of the guys that had the flashes done early last year had to get them redone cause of speedo being off.
stormin norman
- Dec 11, 2007
- Southern, MN
- 2014 Yamaha Viper LTX LE
2000 Yamaha SRX 700
1999 Yamaha V max 500
1992 Yamaha V max 4
1984 Yamaha Phazer
Not to be a smart #%& but are you sure it is not set on KM instead of miles?
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
I believe if it was on KM it would be reading higher than actual MPH not lower.
Right so maybe its on miles instead of KM? OP is Canadian. Bet that is whats wrong stormin normin had a very good suggestion.I believe if it was on KM it would be reading higher than actual MPH not lower.
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
I bet you need the second 16 reflash! I had mine flashed last year and it's like that. Need to get it to the dealer for update.
hellflyer
- Dec 2, 2008
On the upside it's showing 30% less mileage than I actually put on!
TILAM1
- Jan 26, 2017
- 2017 SR Viper R-TX-SE
- Eastern Ontario
If it were in Km 62 MPH =100 km and 86 KM= 53 MPH. Seems re-flash is more likely the problem.Not to be a smart #%& but are you sure it is not set on KM instead of miles?
Yamasledder
- Mar 7, 2010
- 2020 Viper LTX SE
It's definitely reading in MPH as well as the one I'm comparing it to. A reflash sounds like it might be the fix for it.If it were in Km 62 MPH =100 km and 86 KM= 53 MPH. Seems re-flash is more likely the problem.
Thanks.
Yamasledder
- Mar 7, 2010
- 2020 Viper LTX SE
Is a reflash something that Yamaha will cover or are they going to charge me for it?It's definitely reading in MPH as well as the one I'm comparing it to. A reflash sounds like it might be the fix for it.
Thanks.
Free. Takes 10minutes.
Yamasledder
- Mar 7, 2010
- 2020 Viper LTX SE
Real good. ThanksFree. Takes 10minutes.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
This makes perfect sense, the early 16 flash was off approximately 10 mph in the upper digits.If it were in Km 62 MPH =100 km and 86 KM= 53 MPH. Seems re-flash is more likely the problem.
SounderMN
- Sep 26, 2011
- Minneapolis, MN
- 2015 Yamaha Viper LTX DX
I had this issue, and the reflash fixed. No charge, pretty quick.
viper strike
- Dec 22, 2016
- belle plaine mn
- 2015 yamaha sr viper ltx dx
The reflash is a free dealer upgrade. It is free so they dont have to replace your starter instead. Due to the hard kickbacks the 14s had. Even if its out of warranty most reputable dealers will take care of it.
