arteeex
Rear seat hand warmers are called "pockets". The passenger will have two sets to choose from.
horkn
GT03235 said:Why bother with handwarmers? it will just be the same as the front warmers lol
I knew someone was going to go there.
If my passenger gets cold hands, I hear about it. From time to time the passenger warmers on my venture go wonky and apparently don't heat well enough. The my GF lets me know....
I even put the SPI handwarmer kit on it and it apparently is not much better, even on high. Granted, I almost never ride on the back, so I have to go by what she says.
horkn
arteeex said:Rear seat hand warmers are called "pockets". The passenger will have two sets to choose from.
So really only 1 set then. If my co pilot chose her pockets, she wouldn't be on the sled very long.
On a side note I wouldn't hear her complaining abut cold hands, but I am sure I would hear a lot of other verbage about the ordeal
horkn said:How difficult would it be to add hand warmers to that seat jack?
That looks really good on the nytro. When it is removed, is there any hardware left on the sled? And how long does it take to take the seat jack off and back on?
The only part left are the rails the seat attaches to. Un noticeable until your up close. To remove it takes about 2 min. Hand warmers could easily be added, get the RSI warmers, an wire them up to the battery, with a switch. Just make sure you leave your self a disconnect for when the seat is off the sled.
NorthernOnt
- Feb 10, 2009
Bamboo said:Seat jack works awesome on the XTX. Plus its removable. I give it a 100%.
How is the handling on the XTX with the seat jack?? I know it is an aggressive sled and is good for hard solo riding but how does it handle with two people? Can you sit back and trail tour with 2 people or do you have to be riding it hard (leaning hard)? If you just sit back (2up touring style) does it push through corners?
deanhell
Don't have a seat jack but I do ride with my son (about 110 lbs.) and my xtx handles fine. If it's going to be a long ride I will set my torsion sping to High to handle the extra weight.
NorthernOnt said:Bamboo said:Seat jack works awesome on the XTX. Plus its removable. I give it a 100%.
Seat works great. Dependent on how heavy your passenger is, depends on how I set up the torsion springs. As long as the passenger leans your all good.
hollyjason1977
Bamboo said:deanhell said:Bamboo,
Where did you buy and how much?
I ordered mine direct from Seat jack.
http://www.industriesjack.com/
I looked on the website and did not see anywhere you could buy this
looks great
hollyjason1977 said:Bamboo said:deanhell said:Bamboo,
looks great
I called them and placed my order over the phone.
karl
- Dec 9, 2007
- Whitehorse, Yukon Territory
- 2015 Phazer XTX
depends on what you call sporty - I call this sporty
and it will break trail just about anywhere
the rear seat comes off with two bolts in about two minutes and the sled is sub 600lb ready to ride. you can't buy it like this off the showroom floor but it doesn't take much work to get it to this point.
the rear seat comes off with two bolts in about two minutes and the sled is sub 600lb ready to ride. you can't buy it like this off the showroom floor but it doesn't take much work to get it to this point.Attachments
BombaPolaYama
1050THMPR said:I like this one
I owned (or should say borrowed - long story) a similar sled (07 Legend 800 4 stroke) in the RF chassis and found it tippier than the VL because it has a narrower ski stance. The dealer even told me when I bought it that it was tippy - at least he was honest. BTW, if you call that model sporty I would call the VL sportier. The two-up seat can be removed for solo riding and there are lots of aftermarket parts that can be added because a lot of the Phazer stuff will fit. I didn't like the machine at first because of the tippy nature but now after some adjustments and new skis/carbides I have gotten used to the riding style that is required - a more aggressive ride. And I enjoy the ride and of course going solo it is even easier and more fun to handle. It is a unique looking sled and most people think it is ugly but that is in the eye of the beholder. But like I say, don't buy anything w/o a test ride. It is definitely not issue free but worth considering I think.
I'm surprised at so many recommendations on the Ski-doos on TY 4Stroke!! And calling the TUV sporty - I don't think so - it looks like an old style sled to me! I have never riden one but can't imagine throwing that around on tight trails.
