Apex2006RTX
have anyone else had trouble with the 06 apex rtx spring scrubbing the shock that bad it is wearing the shock? what is the trouble?....need help fast
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
Got a picture?
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
The spring is not touching the a-arm at the back and then rubbing on the shock. If it's touching the a-arm that means that u have bent u'r a-arm. Is the shock rod bent?
Apex2006RTX
it is the shock in the undercarriage.
apltx08
Whats the size of spring and what setting is your "C" clip at...make sure your spring is preloaded to the correct SPEC your spring shouldn't be any shorter than 10.4" when sled is resting with track on ground "no load" and check your SAG see attached doc...
Apex2006RTX
Its the original spring and its in the 2nd c clip position.
apltx08
Like I mentioned in earlier post check to see if its within spec...whats your weight w/gear?
You might have to small of spring for your riding style.
Apex2006RTX
The set in is right and the spring is still scrubbing the spring....needs help have anyone else have this problem....
apltx08
Mine does scrub a bit, jack the rear so suspension is of the ground, grasp the spring with both hands and turn it 1/4 of a turn without changing your cam setting, by turning it in a certain position it somtimes fixes the problem the spring will have a slight deflection/bow and you need to find its sweet spot...keep turning till you find that perfect SPOT!
Apex2006RTX
will its worn the shock that much that the grooves are worn off...
