Todd Beenen
What’s a good snap ring tool for removing sprockets
fourbarrel
Building a collection one sled at a time
Any of the high end tool brands will have what you need but if your not looking to spend big $ on a set then look for some with hardened tips.They will last longer and shouldn't bend when you use them.
Todd Beenen
Angled style or straight?
fourbarrel
Well I'm not sure which would be best,my set has three styles and I don't remember what ones I used last time.Tip size is also something you should look at.If you go with a set of snap ring pliers then get a set with a decent range of tip sizes in at least 2 styles.Most common sets will have straight and 90° but I find the 45° ones will work in a wider range of situations.
Todd Beenen
will do , thanks for your info
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
For type of rings used in our sleds I prefer the square nose pliers.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
I was recently needing a set myself, and I found a good set that has worked well at Lowe's, a Craftsman set...
most of the matco tools, mac tools, gray tools and unitool snap ring pliers i have used/own are basicly the same other than the labeling.
the one thing i have found using this style is that i hate the new quick change style as they seem to come apart more than the older ones that used a screw to swap with a stiff snap ring.
i do reccomend ones with a warenty as i have used some knock off ones that look identical to mine that some one handed me and they twisted in my hand tying to pull a snap ring that mine pulled easily.
i do know i hate the ones with changeable tips with a passion as when using the 90 or 45 degree tips they never stay tight and i tighten them almost to the point of stripping the fastener head.
