bigdave
- Dec 18, 2003
- sylvan lake, Michigan
- 14 Viper LTX SE, 14 Viper RTX SE , 08 FX Nytro , 07 FX Phazer, SOON 2017 Sidewinder LTX LE Blue
Fuel leak
This was a different sled ! Mike and I bought them around the same time but his is black and red and mine is blue and white both LTX SE I will have it back at the dealer Monday to close the loop with Yamaha.
Mike1157
- Jul 24, 2013
Sr Viper Fuel Pump
Just got back from Dealership. My sled happens to be there for oil/chain case tension check.
Dealer was grateful to Forum for the info. He showed me where it was at on my sled and was able to feel the clamps and determine they were installed. He is contacting all his customers right now with detailed instruction on how to check it.
He said many years ago there was a similar issue with a Yamaha model it was very isolated and no major incidents occurred but he did find one of his customers sled with a clamp not installed from factory on a fuel line.
Human beings, it can happen. I am sure they will track it back.
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
- 2017 YAMAHA SIDEWINDER LTX-LE
1998 MACH-Z
Just checked mine for piece of mind, both clamps were attached and crimped. Pulled on it pretty damn hard no way that its coming off.
Thanks for the tip
Thanks for the tip
sounds like yours was being instaled friday at 5.00pm.everybodys talking where there going for beers after work and yours never got tightened.
RXVIPER
- Mar 4, 2010
- Shelburne ,Ont
- 2014 SR Viper LTX
2003 RX-1
Good everybody's ok, checked mine today everything's nice and tight. Thanks again for the info.
Good here also. Leaving it a sticky though just so new sled dealers and owners look. Thanks for heads up and pics. Makes it impossible to deny. Hope you turned it in to your dealer also.
My_nanc
Mine was driping fuel. I used my crimping tool to tighten it up. If it leaks again i will replace the crimp. Or run a slightly longer hose. It pulls down on it a little by being so short.
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
I changed all the fuel line pinch clamps to high pressure clamps. Not worth the risk, being sprayed with gas and the sled starting on fire then me!
This did in fact become a recall way back in 14. In 15 or 16 they eliminated the fuel filter altogether. Always good idea to keep an eye on any fuel line connections though. Line itself also. Worst thing ever to watch your sled go up in flames. It happens to all brands.
savageman69
- Apr 21, 2014
- 2014 arctic cat zr 7000 limited
wonder why they removed the filter?...i just changed mine this year, expensive but i like having it
tapex_07
- Feb 15, 2009
Yup it's terrible to see. Had an Apex burn up right under my nose.This did in fact become a recall way back in 14. In 15 or 16 they eliminated the fuel filter altogether. Always good idea to keep an eye on any fuel line connections though. Line itself also. Worst thing ever to watch your sled go up in flames. It happens to all brands.
Cheaper,Less chance of failure at assembly is my guess. I assume there is the normal filter at fuel pickup. If so and its like Yamaha uses I cant think of anyone who ever had to replace one even with well over 20000 mi on. I think that filter on our 14's is just a Fram filter. Probably can cross refrence to a Napa or many other brands.wonder why they removed the filter?...i just changed mine this year, expensive but i like having it
Chief Gotta Go
- Feb 14, 2018
- Frankenmuth Michigan
- SR Viper LTX
My 2015 Viper Ltx Fuel filter started leaking after 500 miles .......could smell strong smell of fuel . was dripping onto engine heads .....replaced filter and put hose clamps on . Dealer warrantied . Filter is located up by steering post
Medieval racing
They were on recall back in 2015 due to that problem
