DK
- Feb 27, 2005
- Logansport, IN
- 2012 Nytro XTX
1998 SRX
1980 Exciter
1988 Sno Scoot
1989 Kitty Cat
I know this is for Four Strokes only, but I have a problem trying to get my track replaced in my SRX. I have the driveshaft installed but the bearing on the clutch side will is not fully seated into the frame, it is sticking out by about 1/4". It looks like the driveshaft needs to move towards the chain case, the question I have does the driveshaft need to be flush with the lower gear in the chain case?
I am just wondering because I cannot get the bearing fully seated on the clutch side and cannot get the driveshaft to move any more.
Is there something that I am missing or what? Or does the bearing on the clutch side stick out by a 1/4"? To me it looks like it should be flush with the tunnel.
rlbock
srx drive shaft
The bearing does stick out about a 1/4" on the clutch side, and the shaft doesn't come out flush with the sprocket in the chain case. It sounds like you have it correctly put together.
Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
SRX forum
DK, you can also post your question on the other TY forums. They have an section that's specifically for SRXs.
http://www.totallyamaha.net/forums/
DK
- Feb 27, 2005
- Logansport, IN
- 2012 Nytro XTX
1998 SRX
1980 Exciter
1988 Sno Scoot
1989 Kitty Cat
Thanks for the info, it looks like the track is centered in the tunnel. So I think I got everything in the right place.
Thanks again.
Thanks again.
- 8K
