Fleecer
- Jun 13, 2014
- 2019 SRX
21/41, stock sleds, no tune.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Your neighbours cat what gears was he running to achieve 137.21/41, stock sleds, no tune.
stgdz
- Mar 27, 2021
- Buffalo MN
I was looking for the QS3-R model sidewinders and 9000's. Found a tcat with IACT and after spending a weekend with it I knew I made the rite decision.
Speedo I assume, not GPS21/41, stock sleds, no tune.
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
The tcat fleecer is referring too at 137 is not running stock gears. The testing between 1.25 track and 1" track was on stock winder 21/41 gears is what I believe he was trying to say.Speedo I assume, not GPS
justinator
- Mar 25, 2007
- Maine
front shock springs and rear torsion springs are different and that is it. There are no other suspension differences. The springs can be retroffited to any other 137 model. I have srx springs all around on my ltx-se.Thanks all for the feedback. How did they go about lowering the SRX? Is it purely shock length or is there some other changes. I guess the 1" track is the standout difference, and I assume going to a 1.3 or 1.5" track isn't going to run into problems? Like an ice storm for instance. I definitely would not enjoy a 1" track around here.
Fleecer
- Jun 13, 2014
- 2019 SRX
22/37Your neighbours cat what gears was he running to achieve 137.
Fleecer
- Jun 13, 2014
- 2019 SRX
Yes, speedo speeds.Speedo I assume, not GPS
Racy2
- Mar 16, 2005
- Toronto, Ontario
- 2022 Sidewinder SRX LE
Could not describe the SRX any better, just the facts. Where I ride and how I ride the SRX is well suited!!!!!Love those facts about why Yamaha chose that set up for its fastest stock sled ever!
My choice would certainly be the SRX with it’s smooth fast characteristics, and it’s great handling capabilities that are qualities of it’s lower stance and 1” lug track!
All depends what you ride where. I’m a smooth fast trail type with a mix of some air at high speeds! Fun factor x2!
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Do you ride the southern ontario trail system?
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Do you notice a definite difference in ride/handling? Would the Thundercat springs be the same as the SRX springs?front shock springs and rear torsion springs are different and that is it. There are no other suspension differences. The springs can be retroffited to any other 137 model. I have srx springs all around on my ltx-se.
Racy2
- Mar 16, 2005
- Toronto, Ontario
Yes if the snow conditions are favorable. Have been to Lake Simcoe running from Bradford up the river to the lake. Conditions in Ontario have not been that great so far. This year I have made 2 trips to Quebec where it is cold and they have a ton of snow. Got a lot of looks as the SRX really sticks out among mostly SkidoosDo you ride the southern ontario trail system?
justinator
- Mar 25, 2007
- Maine
Never road this 2022 ltx se with stock front springs so I cant say for sure. I ran the rear atock torsions a bit before switching to srx torsions. Definetly lowers ride height and I have to run the srx springs a little stiffer setting. They are supposed to be same rate but with just more i initial sag but definitely acts like a softer spring. Yes tcat springs are the same.Do you notice a definite difference in ride/handling? Would the Thundercat springs be the same as the SRX springs?
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
We have ridden quite a bit around here. Up to Fenelon falls, over to ganaraska, etc.. Our really close trails are a mix of goat paths, single track, and just tight and windy until we get to the more major trails. From my place I can get to the H6 or E108 to head north, and then we are on more normal trails (for around here anyhow). I guess if I can ride an attak through those goat tracks I can get a SW through them.
Racy2
- Mar 16, 2005
- Toronto, Ontario
Only it will be a little smother and faster if you so desire. Ridden up around Fenelon Falls through Kinmount and up to Haliburton. The old railroad trail is generally one of the first trails open of the year. Mother-in-law’s home is in Kinmount.We have ridden quite a bit around here. Up to Fenelon falls, over to ganaraska, etc.. Our really close trails are a mix of goat paths, single track, and just tight and windy until we get to the more major trails. From my place I can get to the H6 or E108 to head north, and then we are on more normal trails (for around here anyhow). I guess if I can ride an attak through those goat tracks I can get a SW through them.![]()
- 13K
