blown apex
- Jan 29, 2006
- ALTON ILL.
- ristermotorsports.com
has any one broke the stock yamaha replacement stainless y pipes
jackback
Yep, right at the weld were it goes into the main pipe to the muffler, broke right off, 06 Attack with 15000 K on it. Got it mig welded and reinforced and was good. Rivets in bracket were broke and gone had to replace with steel rivets.
Just trying to clarify.......an 06 oem is NOT S.S., but rather titanium. So you broke a replacement S.S. pipe that you had put on later?
an to the O.P. You are asking about the replacement S.S pipes from yamaha...correct?
blown apex
- Jan 29, 2006
- ALTON ILL.
stainless
sorry replacement stainless y pipes
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
jackback said:Yep, right at the weld were it goes into the main pipe to the muffler, broke right off, 06 Attack with 15000 K on it. Got it mig welded and reinforced and was good. Rivets in bracket were broke and gone had to replace with steel rivets.
Sounds to me he broke the exhaust pipe at the muffler which is stainless not the Y pipe.
- 27K
