SharkAttak
sj said:that makes me want NOT WANT TO rush out and buy another yamaha!
it's just seems as though these machines are starting to fall apart to quickly
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
they have a few issues..some more hassle and expense than others...
I have a question for you metal/welding experts..
is there any way cut off then to weld stainless steel on the end replacing the titanium end?
Iceman57
sj
The ends are not the only place that are cracking on the pipes. Here are a few pix from someone that welded cracks in his pipes near the tunnel mounts.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
seems like there should be some vibration dampening at key areas ..
offtopic...how do you like the power commander / ignition module setup?
berge75
From what I've seen working on dirt bikes and quads,the ti. headers hold up much better that stainless.
The exhaust needs a joint in the middle of the tunnel,or rite behind the two y pipes. If they would use a joint similar to what they used on a two stroke exhaust with the doughnut and some sort of spring mount it would allow for the flex we're seeing.
Iceman57
sj said:offtopic...how do you like the power commander / ignition module setup?
It's a sweet setup. I really needed to add a lot of fuel down low to compensate for the increased airflow of the Excell. The sled missed real bad do to a lean condition that is now solved with the use of the PCIII. I have combined several maps for the fuel and timing and it now runs real strong.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
I agree!
RX1 Yooper
y pipe
Christmas Sports still has 2 pipes. 906-387-3409
SharkAttak
if Excell does them how much h.p. will we gain?
AIRWOLF
Guest
- Oct 1, 2004
- New York
- www.sledpartsgarage.com
Frustrated with Yamaha
with Parts being on backorder,,,,,,,,,,,,,,,,,,,,,
Very unacceptable !!
the season is too short
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
I think they've been caught with their pants down on this one...not having a clue there would be this problem
welterracer
my Y-pipes are in..
Sled is going to the dealer on monday for the repairs..
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
I STILL THINK A FLEX JOINT WILL SOLVE THIS PROBLEM.
BA APEX
rxwhopper said:mine hit 4300 miles today and guess what, exhaust is leaking. is there a link on the procedure to take it apart?
I put ROCKERDAN's write-up plus other mods on a site for easier viewing ----> http://yamahamods.8k.com/ <----
SLEDSTART
Only read a few pages of this thread. This issue is what led me to decide to part my RX. I had about 6800 miles and sled starting backfiring. End result was everything was shot in the doughnut area. Also had a cracked w arm and torn out RA cable (again)
And I wanted an Apex...
So...I love the Apex so far...just broke it in and have 550 miles on her.
My question to you guys is this. Can a BETTER doughnut be made instead of a stainless Y pipe?
Would it not make more sense to make a doughnut that lasts?
I literally had almost NOTHING left in doughnut material on the RX when I tore it apart.
I plan on just changing my doughnuts every 2K as maintenance on the Apex but it would be nice to get a better longer lasting doughnut. Has this been brought up? Everyone seems to focus on a better Y pipe. Don't need it if we can get a better doughnut right?
