The5zops
- Feb 2, 2022
- Michigan
- 2006 yamaha venture rs
I had my 2006 venture out ice fishing today. When I got off the ice after about a 4 mile trip I left the sled running when I got back to my truck for about 5 to 10 minutes. I had the orange triangle warning light come on and the sled stalled. Is this normal from leaving it run that long just setting there? Or what issue could I have.
The5zops
- Feb 2, 2022
- Michigan
It did start right back up and the light went off.
Normal.
It didn't stall, it got hot, and the ecu is programmed to shut er down
x2. have had it happen on a few yamaha sleds.
smokingcrater
Need yourself a set of tunnel mounted scratchers if you are on ice without any fresh snow. Pretty sure the venture has a cooling fan already which helps a huge amount but as you found out, can still overheat with ice and idling.
The5zops
- Feb 2, 2022
- Michigan
ThanksNormal.
The5zops
- Feb 2, 2022
- Michigan
YesIt did start right back up and the light went off.
The5zops
- Feb 2, 2022
- Michigan
Definitely getting scratchers. Thanks for the replyNeed yourself a set of tunnel mounted scratchers if you are on ice without any fresh snow. Pretty sure the venture has a cooling fan already which helps a huge amount but as you found out, can still overheat with ice and idling.
