Amsoil 1
Any problems with starter, it start very slow a couple of times and now it just sounds like it is spinning and not turning over engine
SharkAttak
if it's new bring it back to the dealer
If you or dealer take starter out make sure that the starter bolts that hold body on did not loosen. This can make starter spin backwards and not engage.If thats not it they problably will replace it.That can get very pricey. 800$ plus with labor.
Amsoil 1
any idea's where the starter is located and what to take off
DaveRX1
starter is under the motor. Take off panel under oil pan, starter will come out with motor in, but it will take a while to get it in just the right position to get it out. I do think that you can realign the magnetic stator (green line) with the alignment marks on the brush assenbly with the starter in place
Great info.Thanks.
