pete
- Jan 7, 2015
- 2010 vector
I have a 2010 vector, the sled had power but would not turn over, I installed a relay from e bay, it was the same, did not mount the same, I do nott think I wired it wrong, still does not turn over with key, you can start it by crossing the two poles on the relay, could it be the key switch? thaks pete in wi.
An Apex relay looks the same but is set up differently than a Vector. Its been awhile but one uses a single fuse and the other machine uses both fuses. Double check how the power is transferred to the fuses on both relays.
