dixopr
- Apr 28, 2015
- FGH
- VK pro 11
Nytro mtx 08
Any one pulled a starter off a vk professional 2010 era machine? Pretty sure mine pooped the bag. Looks like a terrible job. Any advice would ve appreciated.
Psycho Dave
- Jan 8, 2013
- Norderåsen
- Sweden
- 2021 Arctic Cat Riot X
1986 Aktiv Karibo
In my opinion the easiest is to remove the engine.
BACK COUNTRY YAMAHA
- Nov 26, 2015
- newfoundland
- 1997 vmax 600 sx, 99 venture 600, 2004 vk 540, 2006 Yamaha vk pro, 2009 venture multi purpose and 2006 venture 500 xl current ride 15 rs viking pro
You can the replace the starter without removing the engine or letting the exhaust go! Remove the engine mounts bolts, take out the breather box, battery box and support, pull the radiator out to one side, once that,s done remove the oil filter then the starter and pull it out the oil filter access hole, it's tight but it will come out then install in reverse! Just did my father's pro, done in about 2.5 hrs. Cheers ! By the way royal distributing sells the same starter for less than half the price of what the dealers are selling them for!
dixopr
- Apr 28, 2015
- FGH
- VK pro 11
Nytro mtx 08
Wow that's great. I was looking at it and wondering if that was possible. Buddy did his nytro without pulling the engine and it was about a 3 hr job too. I'll get to it this summer. Just waiting on parts. I found a cheaper starter too. Cheers.
PD
PD
dixopr
- Apr 28, 2015
- FGH
- VK pro 11
Nytro mtx 08
Well finally got around to pulling the old starter and putting the new one in. Still a crap job but got it done. I didn't move my rad at all but pulled the break and clutch off. So yeah, carbs forward all comes out, including the battery basket. flipped it on its side and through the oil filter you can just reach the bolts holding the starter in. Have not got the old gal out yet because end of the night fuel wasn't flowing out the fuel pumps, not sure whats up with that.
Deeppow16
- Oct 19, 2015
- Montrose, Minnesota
- 2016 Arctic Cat M8000
2002 Polaris 600 XCSP (Sold)
Yeah started are a pain that's for sure. I replaced one in my nytro last winter and it was has a half day job. A lot of parts had to come off in order to move the engine far enough forward for it to fall out the bottom.
dixopr
- Apr 28, 2015
- FGH
- VK pro 11
Nytro mtx 08
Having a strange issue now. The fuel pumps (vacuum - carb) don't push fuel through the outlet. Fuel goes into the fuel pumps from the tank, the crankcase is pulling vacuum. The pumps are clean, I pulled them apart, the diaphragm is good, spring is good. I pressurized the fuel tank with compressed air. Just can't get fuel out of the pumps. Any insights from anyone?
Cheers
Cheers
dixopr
- Apr 28, 2015
- FGH
- VK pro 11
Nytro mtx 08
Got the fuel pumps working again, just needed lots of vacuum. Filled carb bowls and used starting fluid to get it sucking then hooked up the fuel lines. Something is up with this machine, I'm wondering if the carbs are out of sinc, it goes into high idle then when it comes down, it has a hanging idle.
