wildmann
- Dec 11, 2005
- Southern WI
- 16 viper rtx-dx
11 venture gt
09 vector ltx gt
05 vector
2005 vector starter engages only sporadically, started this last year, I checked electrical connections, cleaned and dielectric grease on relays, how much of a pia is it to get to the starter cable. you can turn the key 50 times with nothing, then all of a sudden it will turn over. any help is appreciated
super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
Sounds like a bad starter relay. Next time it won’t turn over touch a screwdriver between the 2 posts on the relay. If it turns over there’s your problem.
wildmann
- Dec 11, 2005
- Southern WI
- 16 viper rtx-dx
11 venture gt
09 vector ltx gt
05 vector
which relay is the starter relay, there are 3 in a row down by right foot, is that the right spot?
he is talking about the one by the air box on the right side of the sled.
wildmann
- Dec 11, 2005
- Southern WI
- 16 viper rtx-dx
11 venture gt
09 vector ltx gt
05 vector
got it, thank you for your help
steveg_nh
- Jul 23, 2017
- Southern NH
- 2007 Attak
I've been trying to solve the same thing. https://ty4stroke.com/threads/solvi...osion-and-air-intake-screw-tightening.149010/
I just ordered a new starter relay. I tried a used one, but am thinking that one has issues too. I would imagine it's to be expected that they will only last so long.
wildmann
- Dec 11, 2005
- Southern WI
- 16 viper rtx-dx
11 venture gt
09 vector ltx gt
05 vector
do you just replace the 30 amp fuse or the whole thing?
steveg_nh
- Jul 23, 2017
- Southern NH
- 2007 Attak
I am replacing the whole relay. The fuses are likely not the issue, unless you have severe corrosion on their terminals. Usually corrosion will be on the relay pins, or the relay will be failing inside. For $50, and piece of mind, I'll just replace it. If I'm wrong, and it's not that, at least I know it's new and good for a while.do you just replace the 30 amp fuse or the whole thing?
Did you check for corrosion on the relay and it's white connector plug?
wildmann
- Dec 11, 2005
- Southern WI
- 16 viper rtx-dx
11 venture gt
09 vector ltx gt
05 vector
thanks, where did u order from, or did u just go to dealer?
steveg_nh
- Jul 23, 2017
- Southern NH
- 2007 Attak
I ordered it online.
radianguy
- Jan 1, 2007
Ignition may be getting bad also. Check ign plug in too.
I'd also check kill switch.
Lots of possibilities.
