maniac
went to start my sled this weekend and all it would do is click the first couple times i turned the key and then it finally started did this twice this weekend after sitting overnight temps wwere minus five thanks for any help. im thinking starter relay?
radianguy
- Jan 1, 2007
Sounds like starter relay, mine did the same thing first year I had it and dealer replaced it with an updated part #. It would eventually start like you said, I guess once power got to the relay it would thaw maybe?? Mine only seemed to happen if I was riding really deep powder and it was cold overnight.
Mtnviper
- Aug 19, 2003
- Burlington Wa.
- fourstrokesolutionsllc.com
Yes, sounds like a starter relay (solenoid) alright.
When you go to install the new one, I like to apply some dielectric compound to the connector that plugs in on top, it helps fight corrosion.
Also don't for get to dis-connect the ground cable from the battery first, to prevent the chances of creating a 12V arc welder with your tools!
Bill
Bill
maniac
thanks guys for your help
