Stealth big wheel kits summer priceing!!
sabrecat
Vendor
J&T PRODUCTS STEALTH BIG WHEEL KIT!!
SUMMER PRICES!!
All RTX 129 inch track models will be $215.00 for the 7.5 kit. That is $35.00 off retail!!
All 137 inch tracks or longer models is $235.00 for the 8.5 kit. That is $35.00 off retail!!
This pricing ends September 15th!! NO discount for stock size trihub or 4th wheel kit!!
J&T stealth kit offers the best big wheel kit on the market!
Some of these benefits listed below are not offered by anyone else!
Out kits have a much larger diameter inner axle. The outside wheel mounts have steel
pins that lock into the track adjusters to hold the wheel in place instead of other companies
mounts that just use the bolt to hold wheel in position. The bolt have reuasble locktight
pre applied and ready to go. ALL the aluminum is anodized black to prevent corrosion from water and salt
not to mention a great look! You can choose clear anodize for the outside mounts. All wheel bearing are about
twice the size as stock ones and are replaceable. All aluminum mounts and axles have lifetime warranty.
* does not cover lost parts or wheels*
7.5 wheels are solid with star design.
8,5 wheels are open spoked design.
To get your Stealth big wheel kit you must call to order 1-810-545-0066
Have a great but short summer!!
Todd
JT Products
price on xtx kit
2 wheel or 4?
I'll be calling you Monday. Still struggling with the 1/2" larger than the stock TriHub. Seems like a lot. You can explain when I call. Thanks.
