Stealth big wheel kits summer priceing!!
Can I get a shipping price to Canada from your web site?
As of the end of last season it was $49 us dollars to ship to CA. We have a whole lot of these kits up there.
Thx
Just a reminder guys if you don't want to go with the stealth kits we have the bullet proof heavy duty tri hub replacement kits also. Or if you feel good about adding outside rear wheels kits that are available in 5 colors. this kit is not like the factory kit you can buy. heavy duty with much better design. And with all my wheel kit the aluminum axles and spacers are all black anodized for looks and to stop salt water corrosion. "seized on bearings" We can't hardly wait for the first snow! How about you?
Stock RTX or any 129 inch tracks is just a little bigger than 7 inches. All 137 or longer tracks will use the 8.5 kit. FYI
That does clear up much confusion thanks!
Can we get them from a Cdn distributor or do we buy directly from you and you ship to Canada?
Yes. I contacted Todd at J&T and he gave me ORPS Parts contact info in Newmarket ON, they also advertise J&T's products on kijiji. I contacted OPRS and they said they didn't have stock but would call me back with pricing, availability, etc. Been over a month and I never heard back so I guess I will order direct from J&T. Let me know if you have any luck....
http://www.orpsparts.com/
http://www.kijiji.ca/v-snowmobile-p...it/1099896741?enableSearchNavigationFlag=true
Also our wheel kits are sold in CA by Aberfoyle snomobiles in ONT. FYI
Jim is a busy guy and might have forgot to get back with you. I am guessing he will be putting a order together soon to stock up for the season.
I bought the last shaft and stock sized wheels from orps a couple months ago so he does stock them.
So just to be clear both sizes of rear wheels were dragging? Even the newer larger 8" wheels for 2016 137's are supposedly dragging the track clips as well?
Yes the wheels sit up higher than the hyfax does. So the hyfax wear and cause drag on clips and track. All the procross sleds are like this.
At $49 shipping and todays exchange rate would be about $350 Canadian
plus maybe get hit with duty
I can't justify that
J&T PRODUCTS STEALTH BIG WHEEL KIT!!
SUMMER PRICES!!
All RTX 129 inch track models will be $215.00. That is $35.00 off retail!!
All 137 inch tracks or longer models is $235.00. That is $35.00 off retail!!
This pricing ends September 15th!! NO discount for stock size trihub or 4th wheel kit!!
J&T stealth kit offers the best big wheel kit on the market!
Some of these benefits listed below are not offered by anyone else!
Out kits have a much larger diameter inner axle. The outside wheel mounts have steel
pins that lock into the track adjusters to hold the wheel in place instead of other companies
mounts that just use the bolt to hold wheel in position. The bolt have reuasble locktight
pre applied and ready to go. ALL the aluminum is anodized black to prevent corrosion from water and salt
not to mention a great look! You can choose clear anodize for the outside mounts. All wheel bearing are about
twice the size as stock ones and are replaceable. All aluminum mounts and axles have lifetime warranty.
* does not cover lost parts or wheels*
7.5 wheels are solid with star design.
8,5 wheels are open spoked design.
To get your Stealth big wheel kit go to our website and order. be sure to click drop down box for your models. The $35.00 discount has been included.
www.jtatv.com
Have a great but short summer!!
Todd
I always check out these add ons from companies like yours , as they only make a great sled better .
I see the features of the big wheel kit , can you list the benefits of the kit , as that may help to sway sledders like my self , to go ahead and purchase.
Also what is the benefit of adding the outside wheels also , as this will be my first sled without them .
Thanks for the help .
