There has been no duty charges but yes it is easy to see your point. Thats why I have dealers up there. Its a little early yet for dealer to stock up but it will be soon.At $49 shipping and todays exchange rate would be about $350 Canadian
plus maybe get hit with duty
I can't justify that
Thx
Hi.I always check out these add ons from companies like yours , as they only make a great sled better .
I see the features of the big wheel kit , can you list the benefits of the kit , as that may help to sway sledders like my self , to go ahead and purchase.
Also what is the benefit of adding the outside wheels also , as this will be my first sled without them .
Thanks for the help .
Four is better than two if your into durability. The stock two wheel set up that comes on them is cheaply built with way to small bearings. It helps with keeping the track more in line and will put pressure on studs if you use them. For lots of people we like the look as well. many think they look like parts are missing with no wheels on the outside. You can see track alignment and that a lot easier than the way you book says to do it. If you just dont want outside wheels then be sure to replace the stock set up with our trihub replacement kit that is made to last. Others may have other reasons they bought out kits.
thx
Todd
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Does the 8.5" 4th wheel kit come with center caps?
krm
- Apr 22, 2016
- ny
no
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
I like the finished look of the caps. Has anyone found caps that work?
There is no cap that will work unless you have someone put the wheel on a lathe and fab them to work. The wheel was not designed for a cap and is no way for the cap to fit and stay.I like the finished look of the caps. Has anyone found caps that work?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
unless you find a cap that covers a stud...the kind that has a washer looking thing and the cap snaps on the washer..
something like this?
https://www.amazon.com/Cruiser-Accessories-82050-Screw-Covers/dp/B00032KC3K
or this...
http://www.toolfetch.com/vestil-bc-...nvRqB3Ijox6yUnHo43y-LjXmtYAc59Lto8aAoo38P8HAQ
or this...
krm
- Apr 22, 2016
- ny
no lip in the wheel .but the doo ones fit .i just checked on mine .you'll need to glue them or cut a lip in them with a dremel or lathe
Sidewinder
- Mar 19, 2005
- Ontario Canada
- www.streettechracing.com
- 2017 Yamaha Sidewinder LTX LE
- Waterloo
Another dealer coming in from KW very soon .
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
post a pic please
krm
- Apr 22, 2016
- ny
lowes also sells hillman plastic end caps .they even have a yamaha blue color .post a pic please
WINDER1987
Got my 8.5" wheel kit today thank you all I lack now is a new sidewinder to put them on
Hi guys!
We have not been able to get 7.5 inch wheels in for the season yet so we have a thick back order folder on them. Supposed to be the end of this month before they get released so we will let the sale go until we get stock on that wheel. We do have the 8.5 wheel kits in stock so get them now at $35.00 off retail!!
