drunkenrich
Hey guys
Doing my lower a arm ball joints and figured might as well do the steering slop too. Can anyone direct me to what causes steering to have play left to right? The steering system has so many tie rods, dont know where to start. I have already put oilite bushings in a arms, thanks
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Bushings
Sent from my SCH-R530X using Tapatalk
1975FA
The bellcrank bolt holes got wollowed out on my nytro and made a lot of slop.
drunkenrich
where is exactly is the bell crank bolts?
drunkenrich
Are these the bushings you are talking about?Bushings
1975FA
The bellcrank is the pivot the tie rods hook to and another tie rod hooks to the handle bars. A single bolt goes through it and holds it to the sub frame. The bellcrank its has needle bearings in it that should be checked and packed with grease.
revster
- Aug 18, 2004
- La Salle MB
- 2009 Yamaha Nytro RTX SE
I've experienced problems with the bolt 1975FA is describing. The grease from that joint seems to work it's way down onto the threads of the bolt and cause it to loosen. Every second season I add some grease to the pivot point and clean the bolt and some loctite and torque it back on. Since I've been doing that it has not come loose on me.
If you ride for a while with it loose it will oval out the spot where it mounts to the subframe.
- 7K
