1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
If your going to put a heavier center spring in I would also recommend doing these other items also.
Larger/stronger upper cross shaft
Stronger lower shock cross shaft
Tunnel savers at the upper cross shaft mount.
The stock shafts will bend if ridden hard thru the junk with a stiffer spring or with the STOCK spring bottoming out.
