Stock grips and replacement heat elements
jlarrabee
South China, Maine
2013 Nytro XTX 1.75 Backcountry
Can I reinstall my stock handgrips when I put on my new RSI heated grips? Or, should I get new grips too?
It should work if they’re not glued in place. Take a air compressor and cap the opposite bar end. Blow into it and pull the grip off. Should expand and slide off without much of a fight. The rsi grips are much heavier and a better overall grip I found.
Unless I have a premature element failure my grips are usually worn to the point they need replaced also. I've saved and reused them a few times over the years but only if they show no signs of wear. It's a lot easier to cut the old ones and reinstall new.
