Stud pull through
only had one till this last MI trip. the rocks got to it i think.
One more thing that some guys do is re-stud that hole with a dummy stud. Install a stud and backer and grind or cut if off flush with the nut. Most likely the best way to prevent any further problems with that hole.
If I were you tator I'd be looking for a new track. Thats a bunch of pulled out studs!
Did you install studs? If so did you torque them or just zip them up with a gun, I use to be one to just zip them up until I torqued the studs on my renegade, had the first pull through stud at 7000 miles. Same track same studs, on the bad side of that that one stud got the cooler, (long weekend of fixing). I did my viper with 144 no pull through's yet with 3100 miles
Riding the hill you must have a 1.75 or 2 laying around just for fun?
The 1.25" is the only spare I have. I have the same one on mine now with trail studs but want to sell the spare and buy a 1" speed track for mine and run some triggers for a main setup and keep the trail studded track for a spare
i didnt install them, dealer did. i might remove all studs. if i get a different track it will be 1.6 or larger
My brother was riding behind his buddy when one shot out and stuck in my brothers coat! Luckily it was back when leather was in cause it would've went through the material nowadays. He had the worst bruise ever.
