Looks great !! Is that a 1 1/4 Ripsaw 2 ? I'm looking into this product for my Viper, just not sure what pattern to use for 137" track. Would the 4-4-5 work ?I cut the drill bit shorter with a cut off wheel so it could be chucked in the drill to the proper depth. I did a 4-4-5 studding pattern in a 129" ripsaw
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
It's the stock 129" ripsaw 2. The 137" ripsaw 2 has the same three lug pattern with a total of 48 bars. There's a total of 16 groups of the 3 lug pattern so if you do the 4-4-5 pattern then you'd need 13x16=208 total screws.
Thank you Grizztracks..It's the stock 129" ripsaw 2. The 137" ripsaw 2 has the same three lug pattern with a total of 48 bars. There's a total of 16 groups of the 3 lug pattern so if you do the 4-4-5 pattern then you'd need 13x16=208 total screws.
Ndoggct
- Aug 25, 2018
- Ct
- Looking for 18 sidewinder
Hello are you installing tunnel protectors with these? Thx
hognit09
- Mar 7, 2010
- beaver dam, wi.
- 2016 viper ltx le,2016 viper ltx dx
Just finished mine up, not to bad of a job. I did 4 per bar alternating 1 of the bars with 2 studs on one side the 3 bars later the 2 were on the other side. Had 2 of them that ripped thru just as I bottomed them out
Ndoggct
- Aug 25, 2018
- Ct
Did you put tunnel protectors?Just finished mine up, not to bad of a job. I did 4 per bar alternating 1 of the bars with 2 studs on one side the 3 bars later the 2 were on the other side. Had 2 of them that ripped thru just as I bottomed them out
I have not put in tunnel protectors in and have no damage after 3500 + miles but did put in the cooler protectors in the rear on a sidewinder.
hognit09
- Mar 7, 2010
- beaver dam, wi.
No, I think there already there from the factory on the vipers
yamaha4sea_fan24
- Jul 30, 2018
- Townsend, WI
- 2018 Yamaha Viper RTX
2018 Yamaha Viper RTX - Wife's Sled
- Townsend, WI
Correct, already on the Vipers.No, I think there already there from the factory on the vipers
Fast
- Sep 25, 2018
I guess your not using tunnel protectors since studs are in line with them,the owner of the company said no drilling requiredI cut the drill bit shorter with a cut off wheel so it could be chucked in the drill to the proper depth. I did a 4-4-5 studding pattern in a 129" ripsaw
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
I'm still running stock tunnel protectors and none of the studs are in line with the protectors. The stock tunnel protectors are positioned over the track windows. The igrip screws need to be pre-drilled for proper installation and I believe that is in the directions. It's important when drilling pilot holes to keep the drill bit centered and straight in the lug so the studs have as much material as possible to hold them in place. Even when pre-drilling it's easy to get them off center and not straight in the lug. I wouldn't even attempt to install the igrip studs without first drilling a pilot.
X2. Patrick from IGrip stresses the fact it needs a pilot.
Fast
- Sep 25, 2018
Do you have a center tunel protector or just 2 above windows?I'm still running stock tunnel protectors and none of the studs are in line with the protectors. The stock tunnel protectors are positioned over the track windows. The igrip screws need to be pre-drilled for proper installation and I believe that is in the directions. It's important when drilling pilot holes to keep the drill bit centered and straight in the lug so the studs have as much material as possible to hold them in place. Even when pre-drilling it's easy to get them off center and not straight in the lug. I wouldn't even attempt to install the igrip studs without first drilling a pilot.
Just 2 above the rails or windows.
rbell14
Installed 200 of these IGRIPS today and drilled a pilot hole as indicated. I don’t think this could have been done very well without a pilot hole.
Best to do this on a fresh track or lightly used track as the paddles will offer more surface area. I had 7,000 miles on my track and some lugs were worn/rounded a bit. That can make it a little tricky which is why the pilot hole helped a lot.
- 7K
